Forgot TDC when Removing Distributor
Old 12-07-2012, 09:55 PM
AAX86
AAX86's Avatar
Default Forgot TDC when Removing Distributor
Well i goofed. I've been having quite a few problems with the car lately. One being i broke the distributor's holding bolt inside the block. Not related though..
Today I took the distributor out without cranking to TDC cause i was frustrated and trying to get work done so i forgot and immediately after, realized what i had just done. However, i took the distributor out a couple days ago and i marked it at TDC then. So my question is, if i take it to TDC again, and then use the mark i made a couple days ago, will it be fine? Otherwise i don't know what to do.
Thanks in advance
AAX86 is offline
Old 12-07-2012, 09:59 PM
mattdel
mattdel's Avatar
Move balancer to 0 degrees timing, drop dizzy in aligned with #1. Attempt fire. It will either be perfect, or 180* out.
Retime afterwards.
mattdel is offline
Old 12-07-2012, 10:09 PM
AAX86
AAX86's Avatar
Retime afterwards.
Alright so that's a yes. So what happens if it's off 180 degrees?
AAX86 is offline
Old 12-07-2012, 11:42 PM
mattdel
mattdel's Avatar
Pull it out a tad and spin it so that the rotor rests exactly 180* from where it just was. Don't forget about the movement from cam meshing.
mattdel is offline
Old 12-08-2012, 01:53 AM
AAX86
AAX86's Avatar
Alright thanks
AAX86 is offline
jwog666
12-27-2021 08:09 PM
bradleyb
11-27-2015 07:50 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Forgot TDC when Removing Distributor
