EGR DELETE
EGR DELETE
i am going to upgrade my stock throttle body to a 75mm and need to know some of the advantages/disadvantages of using a egr delete plate and plugging the lines
i am not sure if i should keep it or not any info will help check my signature for my mods
RE: EGR DELETE
as far as i know and what i want to do is get an egr delete plate wich goes in place of the spacer instead, then the lines must be plugged....
im trying to find out if there are any drawbacks to deleting the egr before i go and do it...
RE: EGR DELETE
no drawbacks and no advantages. it doens't really make a difference either way.
egr is not in effect under full throttle so you won't gain or loose any performance. (assuming its working like it should.)
