Erattic idle edelbrock carb ...?
The holley is a 600 cfm 4010 , looks kinda like the old autolite carbs from the 60's , the top comes of as one piece , a friend gave it to me along with the intake(weiand 2p 180) he had bought to use for another motor and never did , they sat in the garage for 15 -20 years never ran , and that carb held a good idle but just couldnt get it to run right , it didnt have power when you would get into it , tried different springs and settings to no avail . Back to the edelbrock , took the top of and blew it out again and looked at the floats and they checked out , but it did no good , i noticed that when its first started and i have the choke closed in pretty good it sounds ok tho its ideling a little high but when the choke is opened it falls flat , and there is fuel dripping out of the driver side booster and running out of the passanger side booster at idle , i know this isnt right , cant tell if its doing it with the choke closed cause i cant see it , fuel pressure is at 5psi , and i thought maybe the butterflies were open to far at idle pulling the fuel in like that but i dont think thats the case , idle screw is not open that far .
i dont know much about edlebrock carbs because they dont make good power at all. it is not supposed to be leaking fuel like that, it should be a nice mist. i would switch back to the holley or try and find a quickfuel. with the holley swap for the better accelerator pump, lightest secondary spring (that way secondaries open sooner) and the bigger power valve. that should make that carb really wake up.
I tried different springs on the holley and didnt help , the pump on it works fine and the power valve iv used a 5.5 and 7.5 and 6.5 and within a day or two they blow , and i can always tell when they have blown because you can open the choke up all the way with no change in the motor on a cold start . I am getting a 600 dp a 4776-2 , and see how it does , im tired of messing with carbs , seems like since i built this motor last april iv been plagued with carb problems , and i cant figure out that edelbrock , iv tried everything and i know it seems like an air leak but cant find it but really seems like something is screwed up on it , probably why i got such a good deal on it no doubt .
