HELP needed with 8.8 rear end
Ok guys i need some expert opinions on an rear end set up for an 94 cobra.i smacked an curb and broke an axle so i kinda wanted to upgrade to an stronger rear end.i already have an 3.73 and pretty much every basic bolt on and an boost in the near future.is there an certain axle/diffy you like better then other.thanks in advance for the help
Agreed the stock 8.8 is plenty for a street car. If your thinking about slicks and a power adder down the road it becomes a matter of how much racing you plant to do and if it'll stay a daily driver. A 31 spline axle and new trac loc is probably about 10-20% stronger than stock but will behave just like stock. It's all about what you want to do with the car. A spool and 35 spline axles will last a lifetime but will suck on anything other than a straight line.
I knew it was a bit wider, but I'd like the rear wheels to be bumped out a bit anyhow, I have an 02 8.8 I was gonna throw on my 04 v6, but just got a 94 gt and know its a higher gear ratio and wanted to make sure it would all bolt up before I start removing the rear from the gt.
