Head Milling
milling it that much may cause you to have to mill the intake as well....but I could be wrong, I'm sure ED could send it out to one of his shops but it's better/quicker to have it done locally, I had a local machine shop mill my intake....but that is a story in itself which got ED to call me personally..lol
I would do that, but everything is getting balanced. I don't want to have to pay for that job twice.
Not sure for what engine you're planning on milling the heads, but for what it's worth, I once had a 289 running 1969 model 351W heads that were flat-cut 40 thousands and angle-milled 62 thousands. I ran a Holley Street Dominator single-plane intake and didn't mill anything off the intake. Bolted it right on and it worked fine. Drove it on a daily basis for nearly 3 years. Was running a .500 lift/300 duration cam and TRW 12.5:1 pistons, too. But.....that was back in 1980 when you could still get 98 octane gas! I don't think I'd use that combination today, which is unfortunate, because that was one mean-*** engine! Bottomline...determine what comp. ratio you want (or can get away with!) and calculate milling based on that. My 2 cents...!
