Air to Fuel ratio
RE: Air to Fuel ratio
I believe in saying salt and pepper shakers hes reffering to how to check for vaccuum leaks. Id Assume his way would be to shake it across to lines and see what happens to it. You could also use a propane torch. Just trun on the flow of gas but dont ignite it, then run the tip over the vaccuum lines slowly and see if the engine changes, youll hear a rev or bog more.
ORIGINAL: TastePAINt88
09-03-2015 07:14 PM
