Radiator support replacement
Old 02-20-2013, 11:22 AM
Js88lx
Js88lx's Avatar
Default Radiator support replacement
How hard is it really..? Is the aligning process critical and hard?
Js88lx is offline
Old 02-20-2013, 12:51 PM
mattdel
mattdel's Avatar
critical, yes. hard, depends on how many people you have to help, and what tools you're using. Bolt-ins are cake, weld/dimpled ones take a bit more finesse.
mattdel is offline
Old 02-20-2013, 03:37 PM
Js88lx
Js88lx's Avatar
thanks. I have an 86 that has a messed up radiator support. I see i can buy it new but the hard part must be the install. How much do you think someone that has experience welding but not a pro can do it for? So the stock one is welded dimpled im guessing.., shouldnt the new one go on the same..? I didnt know you can just bolt on?
Js88lx is offline
Old 02-21-2013, 09:56 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Hardest part for me was cutting the old one out. I had some fun getting my new one in also since my frame rails seemed wider that the replacement support. I ended up plug welding it back in using the holes I drilled for the spot welds, and then put a perimeter lap weld around the frame rails where they hit the support. Lets just say I wouldnt want to get hit with the front of my car.
Boss_Hotrod is offline
Granatelli Sales
01-20-2020 12:34 AM
5.0muscle
01-11-2016 01:17 PM
MusicCity615
09-12-2015 07:05 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Radiator support replacement
