idle issue and high reving when stopped!help!
I was wondering what would cause idle issue like constant idle change from 1500 rpms to 1300 rpms and also when I'm at a complete stop just all of a sudden go thru the roof as if I am slamming on the gas. I was thinking a leak in the intake manifold be I'm not mechanic I could use some help.
Start by pulling your Idle Air Control and cleaning it. If it were a egr problem your idle would be very erratic and it would either stall or act like it wants to stall. A vacuum leak in the intake would likely cause a constant high idle , while a vacuum line that is cracked may cause it to surge or hunt idle. My guess is you either have a faulty IAC or it just needs to be cleaned . While your at it a good throttle body cleaning wouldn't hurt either.
