Serpentine Belt Won't Spin
04-20-2013, 03:23 PM
I put a big bolt in my tube on the new h, If yours has a bung for it you may be able to go to Home depot or lowes and find a plug for it.
04-20-2013, 07:08 PM
Back to the belt - The new belt is squeaking for a split second, only when the car first starts. Any remedies or does this quit after the belt stretches some?
04-20-2013, 07:22 PM
how much does the tensioner spring back after you let it go... my belt barley fit with the tensioner all the way then it only went back a 1/4 inch or so when released .... Maybe your belt is too long...
04-20-2013, 08:16 PM
I'm using a 90.5" belt. I tried an 89.5 and a 90, i moved the tensioner as far as it would go and still couldnt slip the other belts on.
04-20-2013, 08:46 PM
You may want to check your other ribbed pulleys , I had a belt that burned up one time and deposited a lot of burnt rubber in the valleys of all the ribbed pulleys It was a pain in the *** but I had to use a wedged file to clean out all the burnt on belt. It may be why its squealing a little.
04-20-2013, 09:36 PM
Did you have to open the tensioner up all the way to get your belt on? I didnt have to fight w this one to get it on, but half inch shorter and i couldnt get it over the idler
04-21-2013, 03:03 AM
Ya I had to opent the tensioner all the way up and the belt barely slipped over it. I also deleted the ac as well at the same time. I had a ac delete pully on it and I got rid of that cause of squealing . I suspect you have some rubber burnt into the crank pully from the belt not spinning . The belt cant be to tight as the tension is set by the spring tensioner . Possibly the tensioner is getting old and has lost some spring pressure .
04-21-2013, 09:37 AM
I bet the one i have is too loose, it slipped on pretty easily
04-21-2013, 05:28 PM
Got it w the smaller belt. All is good!
04-21-2013, 07:59 PM
JUST went through all this lol. So what all exactly did you delete?
