bad luck???
bad luck???
3 weeks ago my water pump went out...it was leaking water out of the hole telling me that it was at the end of its life..so my mechanic installed a new water pump and everything was fine after that..no more overheating. today i was driving home and my temp gauge started to sky rocket so i pulled over and water pump was steaming like a ****. i let everything cool down and then drove down the block to my house and popped the hood to notice there was water pouring out the exact same place on the new water pump...yall think i could have just got a bad water pump or is there something else wrong that coule be causing this? the thermostat was changed with the water pump..any feedback will help
RE: bad luck???
that sucks dude, it does sound hella fishy.. Although on my '96 i had to get a new clutch, which was also bad, as were the next two brand new clutches......(thats for a grand total of 4 new clutches to get one that was right)........ sometimes shtuff happens, but make sure you rule everything else out first
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
KingRando
10-02-2015 08:06 AM
