Building a trick flow top half 360 hp.
I talked directly to the guys at Trick Flow when I bought my top end kit and installed it.
They told me they have installed this kit on many 302s and with true flat top pistons (which my '86 Capri has) is the best way to go and will deliver 360 hp at the crank.
They also said for this kit you must upgrade to a 255 pump, 24 lb injectors, 70mm TB and a 75mm MAS.... otherwise you're just asking for problems.
Are you running a blower? 255 in tank and inline mostly gor blowers
I'd suggest a 255, 30lb injectors, 73+mm MAF, and a custom tune. Preferably have the tuner dial in the MAF transfer function before "tuning" fuel and timing.
That way it'll be safe and throttle response will be sharp w/o worries. And if in the future you step it up even more, then just a MAF upgrade (or MAF extender) would be all you'd need.
Luke9222
10-22-2015 11:55 PM
uberstang1
09-20-2015 06:42 PM
