It does this entire time. When its cold it wants to die unless I give it some good gas. And guy said it was stock cam. Its timed at 13 degrees idling at 600rpms
I would suggest getting your idle closer to the 700-800 rpm range.
If your at 600 now at 13 degrees of advance I would expect more rpms than you have. because right now with the spout out backing the timing down to the stock 10 degrees would likely cause it to almost stall .
Re do the base idle relearn only this time when you start turn the idle screw till you obtain 700 rpm . I have seen cars that idle at 850 .
Okay, I need to time the again anyways. So you suggest I raise the idle? And Im going to upload two vids. One is idle w/ iac and other is idle w/o iac on cold starts
