Idel problem - getting worse
Welp its stalling all the time now! I donno what it is, I think its the cold weather, so I put the scaner to it, and i think its the idel position sensor, so Im changing that tomorrow hopefully it fixes it, if not then ill be upset. When i sit at a stop light I have to hold the pedal in to make it idel right or it will shut off . Do you think its the idel position sensor?
RE: Idel problem - getting worse
I wouldn't just through parts at it. Try diagnosing the problem before you install something you don't need. Look in your engine compartment for disconnected vacuum hoses or electrical connectors. If you have access to a vacuum gauge hook it up to a vacuum line and see what your vacuum is. Should be between 18-21 in/hg. I willing to bet a vacuum leak is your problem.
LivingInThePast
09-16-2015 12:20 PM
