aod stall question
Old 07-29-2013, 07:14 PM
15austin
15austin's Avatar
Default aod stall question
T5 guy here with a aod question. I just bought a 91 with a built aod. Supposed to be fully built lentech with silver fox valve body with a switch for manual or auto valve body. My question is it stalls very low. Stalling up it will spin Tires at 1200-1300 rpm. At idle you hav to hold brake hard so it wont take off. Is it the converter scrwed up maybe? Anything else it could be? Thanks
15austin is offline
Old 07-29-2013, 09:15 PM
bluebeastsrt
bluebeastsrt's Avatar
Sounds like the stock stall.
bluebeastsrt is offline
Old 07-29-2013, 09:50 PM
88 orangepeel notch
88 orangepeel notch's Avatar
If you have to be hard on the brakes at idle to keep it from going, well something doesn't sound right to me. I'd dig alittle deeper, as in contact Lentech, Silver Fox.
88 orangepeel notch is offline
Old 07-30-2013, 02:23 PM
15austin
15austin's Avatar
I don't kno if its supposed to but when im n neutral or park it idles perfect at 800rpm but soon as I put it in Gear it idles up to 1500or so. It will take off and go thru the gears up to 3rd gear and ill never touch gas pedal. To like 25mph
15austin is offline
Old 07-30-2013, 07:32 PM
Js88lx
Js88lx's Avatar
stock stall! sorry!
on my ex AOD I had a 2800 stall and wheels spun at about 1800-1900 with street drags! I would go with nothing lower than a 3200 stall!!
Js88lx is offline
Old 08-02-2013, 02:28 PM
deputycrawford
deputycrawford's Avatar
My 85 AOD with start turning the tires around 1300 RPM as well. Mine is stock so I ordered a 2300-2500 locking stall and have to get it put in soon. Please give us more details on the raised idle in gear. Vacuum leak? What is your vacuum readings at idle in gear and out of gear and start there. Anyone know if the symptoms could bre realy or electrical?
Jerry
deputycrawford is offline
Old 08-02-2013, 02:30 PM
deputycrawford
Sorry guys. I meant could the problem be relay or electrical? Spelling lol
Jerry
chrisdbassplayer
10-13-2015 06:53 PM
Dathan
10-05-2015 05:52 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: aod stall question
