Sway Bars
Old 09-22-2013, 06:28 AM
yurizx6r
yurizx6r's Avatar
Default Sway Bars
Hey guys, probably a dumb question, but a friend gave me an extraordinary deal on an Eibach Anti-roll kit (both front and rear sway bars). My question is do sway bars and the polyurethane bushings put extra strain on any part of the suspension that I should know about (wheel studs, torque box, etc etc), and do I need to do any other suspension upgrades with them? The only suspension mods I have now are lowering springs and a strut tower bar. Thanks in advance for any help!
yurizx6r is offline
Old 09-22-2013, 07:37 AM
dawson1112
dawson1112's Avatar
The only thing they may put more stress on is the end links. But im guessing that the sway bars came with new end links as well. If not you can get a set of energy suspension sway bar end links to go with the kit.
Really the only thing the sway bars do is help keep the inside tires planted to the road by transferring some of the weight from the out side tires during cornering.
dawson1112 is offline
Old 09-22-2013, 07:42 AM
yurizx6r
yurizx6r's Avatar
That's what I thought. I just wanted me make sure because I'm still running the stock spindles and have not upgraded to the five lug conversion yet. I also just wanted to make sure that it would not stiffen up the suspension so much that the tires lose their independence when I go over a bump on one side or anything. I think it will be fine, but it's good to know in advance.
yurizx6r is offline
Old 09-22-2013, 01:38 PM
adrnlnjnky700
adrnlnjnky700's Avatar
ran eibach pro plus kit on my 4 lug and it worked just fine. the kit did come with new endlinks. really stiffened up the cornering. your going to like them
adrnlnjnky700 is offline
Old 09-22-2013, 06:57 PM
yurizx6r
yurizx6r's Avatar
How in the hell do you put the rear sway bar on!? I got the front on, no problem. The rear I cannot get the damn OEM clips to fit on to the new Eibach rear sway bar and push it up. Is there a trick or is there a part I need!? How did you do it!?
yurizx6r is offline
Old 09-23-2013, 07:19 AM
adrnlnjnky700
It really sucked having to do it to brand new sway bars, but i had to grind off a pretty good part of the swaybar so it would fit up in the control arm. If i was you i would just throw tubular control arms which are better anyways then they have a little bracket on the bottom that is super easy to bolt the sway bar too.
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
fastbackford351
10-01-2015 12:24 PM
winner99
10-01-2015 10:52 AM
09-16-2015 07:53 PM
Quick Reply: Sway Bars
