distributor position?
i have a lil problem i had to take my distributor out to change toh lower intake and now i have to put it back and i dont remember how it goes in(positioned). any help would be great. the crank wasent moved if that helps.
RE: distributor position?
ORIGINAL: 90GTRagtop
If you didn't mark it when you took it out, you'll need to set the crank at top dead center on the compression stroke and make the rotary button point to cylinder #1 on the distributer cap.
You'll need to rotate the crankshaft until the #1 piston is at the top and the camshaft lobes/lifters are in the lowered position such that both valves would be closed if the head was installed. That would correspond to top dead center (TDC) on the compression stroke.
lincolnshibuya
12-08-2015 04:37 PM
bradleyb
11-27-2015 07:50 PM
jaiidutch
09-14-2015 10:29 AM
