Nitrous is installed
RE: Nitrous is installed
we are almost identical in set up except heads,and a hella lighter car than me. if you can get off the line perfect i see 11.60's.
ORIGINAL: BADNOTCH
I finally got my 125 shot installed and dialed in. What a difference in power. I am headin to the strip wednesday to see what it can do. I am thinkin mid 11's.
I run bfg drag radials 245/45/18 on the street and they hook really hard from a roll. But they dont stick from a launch out of the hole. I dropped the pressure down to 12lbs at the stip and they were still spinnin. I managed a 1.699 60ft time with them. I am hopin with the slicks I can get my 60ft time around 1.4
i'm using 275/50/15.i didn't go below 17lbs leary of them. how the hell did you get 18's to hook up?
ORIGINAL: BADNOTCH
My tires are 10.5 inches wide. With low tire pressure they hook pretty hard from a roll. With the nos it spins a little in second and barks third and forth. But it still is pullin forward when they spin, its not like i am baking em.
I am going to be runnin 10inch slicks on a 15 inch wheel. The 18s are my drag radials. I have lakewood suspension all the way around, with eibach air bag drag springs. I took it out today with the slicks on and practiced my launches. I am hopin for 1.4 if i end up with 1.5 so be it. I put down a 1.699 with no nitrous,and 18's. All I can say is with the slicks this car gets it out of the hole. I have my nitrous tied into my throttle. At wot it activates. No pushbuttons here. I will videotape the runs on wednesday and download em.
