Next steps in 5.0 build?
Old 11-24-2013, 12:04 PM
Pyrotech9175
Pyrotech9175's Avatar
Default Next steps in 5.0 build?
Hey guys i'm new here to the forum. I've had my Mustang for a few years now and just drive it on nice days. I have some stuff done to it but i finally want to go a little bit bigger. If anyone knows anything i should do, let me know. Here is my part list so far:
Ford Motorsport 1.7 Roller Rocker Arms
Moroso Cold Air Intake
Performance Solutions 130 AMP Alternator
MSD Coil
Ford Motorsports Spark Plug Wires
BBK Aluminum Underdrive Pulleys
Ford Racing T5 Z-spec Transmission
Lakewood Blowproof Bell Housing
King Cobra Clutch
B&M Short Throw Shifter
Ford Motorsports Aluminum Driveshaft
Ford Motorsports 4:10 Rear End Gears
MAC Ceramic Coated Shorty Headers
Summit 75mm Throttle Body
Summit 75mm EGR Valve Housing
Jegs 1/2" Intake Spacer
BBK Adjustable Fuel Pressure Regulator
Walbro 255 LPH Fuel Pump
MAC Off-road H Pipe
Flowmaster 3" Mufflers
BBK Frame Connectors
Steeda Coil Springs
KYB AGX Adjustable Shocks and Struts
Hotchkis Caster Camber Plates
#25 Racing Spark Plugs
Dorman Radiator Fan
BBK TPS Sensor
Standard LX 223 Control Module
Im not looking for a pure race car. My goal would be a nice low 11sec street car. Let me know your guys opinions i would love and appreciate hearing them. Thank you very much.
Tim
Pyrotech9175 is offline
Old 11-24-2013, 04:10 PM
Bubba 95SN
Bubba 95SN's Avatar
Your budget will be the key to more power. Cylinder head change would be a start.
Bubba 95SN is offline
Old 11-24-2013, 04:37 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
go buy a stroker motor for low 11's or supercharge it, no cheap ways about it
mjr46 is offline
Old 11-24-2013, 05:08 PM
Pyrotech9175
Im not really worried about the money. I want to do H/I/C, but im not sure of anyone around me that can tune. I want to stay NA. I've had many boosted cars and i just want to stay away. I dont mind dumping money into the motor but i dont want to dump $10gs into a fully built stroker motor if i can just put heads...etc...etc...etc on my 302 and be in the same ballpark. I'm was wondering if i put the full upper TF kit on that reaches 360hp is probably your best bang for your buck?
Old 11-24-2013, 06:36 PM
88 orangepeel notch
88 orangepeel notch's Avatar
360 hp (at the crank) will get you mid to low 12's in a street car, maybe high 11's with good drag setup.
And welcome to the forum.
88 orangepeel notch is offline
Old 11-24-2013, 08:10 PM
reldla1996
reldla1996's Avatar
You definitely need heads and intake, and you don't need a tune with an 89, unless you're boosting or stroking. I also did not notice a MA on your list. A stroker engine will have 30-40 ci on a 302, and will make 30-40 hp more, all other things being equal. If your choice is h/c/i or stroking, my choice would be the h/c/i, assuming the short block is in good condition.
reldla1996 is offline
Old 11-25-2013, 12:43 AM
UPRSharad
Former Sponsor
UPRSharad's Avatar
Your shocks, struts, and springs are not conducive to street strip performance driving with an 11-second target. Also, you're missing control arms like these:
http://www.uprproducts.com/mustang-c...ackage-79.html
UPRSharad is offline
Old 11-25-2013, 01:49 AM
tinman
tinman's Avatar
Yep, time to spend moneys on suspension.
There are a lot of company's out there that make good street/strip type parts.
I also think that you need to run this car at the strip to get a baseline on what you have now........
tinman is offline
Old 11-25-2013, 07:44 AM
mjr46
mjr46's Avatar
Originally Posted by Pyrotech9175
I i dont want to dump $10gs into a fully built stroker motor if i can just put heads...etc...etc...etc on my 302 and be in the same ballpark.
then you won't be running low 11's with just a bolt together h/c/i, there have been many who get a h/c/i 302 in that range but don't be fooled then have done lot's of tunning and careful matching and tweaking of the combo, it didn't just come by buying a tfs kit and bolting it together......that way will yield 12's at best
mjr46 is offline
Old 11-25-2013, 09:13 AM
88 orangepeel notch
I'd look at that ET estimator in the stickys, have a time you'd like to run, cross reference the weight of your car, and it will give you a pretty accurate hp level needed to run those times. We're not ripping on you, but your gonna have to be realistic in your goals.
300-350 rwhp in these light foxs make for very fun cars, and the ladies dig them too.
Quick Reply: Next steps in 5.0 build?
