1990 Mustang motor mount replacement
Please give me a basic step by step on replacing my original motor mounts in my 1990 5.0. I assume when you jack the engine up, you have to remove the nuts holding the tranny to their mounts? Also assume it is best to loosen up the motor mounts nuts/bolts first before i start to jack the motor/tranny up? Help- thanks!!!
only do one side at a time. and yeah a block under the oil pan plus a jack will work. iirc i think i actually used the bell housing last time to jack it up when i installed my solid motor mounts
