Injectiors
10-11-2005, 01:13 AM
Injectiors
Would 19 lb Injectors be find with H/C/I and some bolt -on's or 24s will be better?
10-11-2005, 07:01 PM
RE: Injectiors
normally you should change the injectors when you change the heads
10-11-2005, 07:17 PM
RE: Injectiors
you change injectors when you up hte power
24s are a basic upgrade fro a street combo. if you went wild combo then 30s would be needed but i doubt youre going that high
10-12-2005, 12:20 AM
RE: Injectiors
about how much hp can 24s handle?
10-12-2005, 02:01 AM
RE: Injectiors
19's are supposed to be adequate up to 350 fwhp. I was told that if your combo requires you to use more than 44psi fuel pressure to maintain proper a/f ratio with the 19's it's time to move up to 24's.
10-12-2005, 07:48 AM
RE: Injectiors
no way in hell i would take 19s up that high. just not effiecent enough to use them up that high
10-12-2005, 12:16 PM
RE: Injectiors
Yeah I've heard that 19#r's are only good until 300hp. It'll depends on the mods you're going to be doing and then how much of a duty cycle you have to put the injectors through to have it run right.
michal@
04-12-2011 10:57 PM
15austin
03-18-2007 04:03 PM
Booger
4 Cylinder NA and Turbo
15
01-31-2007 08:42 PM
code3GT
03-21-2006 10:50 PM
liteMup5oh
01-01-2006 12:59 PM
