GT40 3bar head porting and flow numbers.
Old 01-06-2014, 09:09 PM
dwb91lx
dwb91lx's Avatar
Default GT40 3bar head porting and flow numbers.
Where's the easiest flow numbers come from on GT40 3bar iron heads...got up to 215/168 currently.
dwb91lx is offline
Old 01-07-2014, 03:16 PM
dawson1112
dawson1112's Avatar
I don't understand the question!
What do you mean where does the easiest flow numbers come from?
dawson1112 is offline
Old 01-09-2014, 03:27 AM
tinman
tinman's Avatar
What lift and what pressure are you measuring at?
Sounds awfully good to me......
tinman is offline
Old 01-09-2014, 10:40 PM
dwb91lx
dwb91lx's Avatar
215/168 @ 400-450 lift... .28" flowing from .1 through .6 lift but mostly interested in low/mid ranges (above .2)
dwb91lx is offline
Old 01-10-2014, 02:35 AM
tinman
tinman's Avatar
I'd make sure that everything is calibrated real good, those numbers sound awful good to me........
tinman is offline
Old 01-10-2014, 07:14 AM
dwb91lx
dwb91lx's Avatar
What do you mean, calibrated...his test equipment?
dwb91lx is offline
Old 01-13-2014, 01:32 AM
tinman
tinman's Avatar
Exactly.......
tinman is offline
Old 01-13-2014, 10:51 PM
barnett468
barnett468's Avatar
What is your question?
barnett468 is offline
Old 01-16-2014, 10:00 AM
dwb91lx
dwb91lx's Avatar
Question was for those that have actually ported GT40 (non-p) heads. I understand that the idea is to achieve the most increased flow by removing the least amount of material...the question is...where is that location @ that gives the best flow results...is it the intake port/throat/bowl or exhaust port/throat/bowl?
dwb91lx is offline
Old 01-17-2014, 12:27 AM
barnett468
barnett468's Avatar
That is a bizarre question imo, because the intake and ex are separate.
The intake obviously, naturally flows more than the ex, so even if you port the exhaust, the intake will still flow more.
This means that porting the intake will provide greater flow than porting the ex.
If one were to port one area or another of either the in or ex, the biggest increase in flow is typically achieved by properly porting the bowl, blending the valve guide and doing a 3 angle valve job.
Quick Reply: GT40 3bar head porting and flow numbers.
