High volume vs high pressure oil pump
Hey guys. I am getting ready to tear into my buddys 88 with a 408 stroker,445hp 470ftlbs at the tires. This motor under a load revs insanely fast. He has the best of everything, the whole car is set up right. A few months ago he started to leak oil out of his seals and gaskets(out of no where). We were thinkin since he has a high pressure oil pump, that could be the problem. I was going to install a high volume oil pump and all new gaskets. He has breathers in his valve covers, which seem to be working fine. What else could I do to relieve crankcase pressure?
RE: High volume vs high pressure oil pump
have the pump clearance by your machinist.....those hi-po oil pump are nice in a 7 qt pan but not a stock pan do to possible foaming and oil starvation.....check the pvc screen
get a melling oil pump, my oil psi is like 62 cold at idle and 35-40 psi hot at idle thats great, also let the car warm up before you take off that is what is hard on seals.
09-08-2015 11:50 AM
