Loud exhaust explosions, too much carbonization and fuel after the throttle valve
Old 06-23-2014, 07:28 PM
matheus.mattia
matheus.mattia's Avatar
Default Loud exhaust explosions, too much carbonization and fuel after the throttle valve
While disassembling the throttle body, I noticed that had too much carbonization and fuel (actually leaked as can be seen on photo) right after the throttle valve (I had cleaned about 1 year ago)... Is this normal? Another problem that I have is the exhaust (it's seems to be) explode(really loud pops) some times when I accelerate and leave the car go by the inercia...
Why is there fuel there? Bad valve timing? And is this causing the exhaust pops?
Thanks!
Attached Thumbnails Loud exhaust explosions, too much carbonization and fuel after the throttle valve-img_0320.jpg   Loud exhaust explosions, too much carbonization and fuel after the throttle valve-img_0321.jpg
matheus.mattia is offline
Old 06-23-2014, 08:28 PM
dawson1112
dawson1112's Avatar
The only way I know of for fuel to enter the throttle body is through the fuel pressure regulator. If it is bad it will let fuel leak past into the intake. Pull the vacuum line off of the FPR and if it is wet with fuel then it needs replaced.
The popping is from having an excess amount of unburnt fuel in the exhaust.
dawson1112 is offline
Old 06-23-2014, 10:29 PM
matheus.mattia
I'm gonna check this tomorrow... But a bad FPR will result in an excess amount of unburnt fuel in exhaust or the problems aren't related?
Thanks!!
Old 06-23-2014, 11:03 PM
dawson1112
dawson1112's Avatar
Bad fuel pressure regulator with a leak in the diaphragm will buld to much pressure and also fuel sucked into the vacuum line to the intake gets pulled into the cylinders as well.
Old 06-24-2014, 05:05 PM
matheus.mattia
It wasn't wet, any other guesses?
msavoia23
12
07-07-2018 12:08 PM
drfister
05-03-2018 10:38 PM
mirandaandjimmy
11-16-2015 08:51 AM
JonnyBlazeGT
11-03-2015 01:10 AM
91StangOwner
08-20-2015 11:34 PM
Quick Reply: Loud exhaust explosions, too much carbonization and fuel after the throttle valve
