Car hesitating after it warms up!
you can ethier buy or get a loan from a autozone if theres any near you , you will need the gauge and its ford converter tip , on your engine bay passenger side , right behind your alternator you will see metal lines with a valve it leads towards the fuel rail ,fuel injectors thats where you plug the gauge in , when its plugged in turn key ignition on , if the guage only moves 3-5psi then thats first signs of bad pump , second turn the car on the gauge should read 38-40psi while looking at it rev the car abit should remain steady if it drops then its a weak pump , you should get codes from self diagnostics from the car i had codes 41 91 and car shut off once in a while under load , you dont want to end up stranded
ShaneB26154
35
03-04-2021 04:05 AM
DrunknRuckus
08-23-2015 10:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
