electric fan problem'o
Old 07-31-2014, 07:48 PM
bebermexico
bebermexico's Avatar
Default electric fan problem'o
i have an electric fan on my stang and the battery light keeps coming on.... i change the battery but now am wondering if i need a high output as far as alternator would an 80 amp do the trick???? or is 130amp the answer?
bebermexico is offline
Old 07-31-2014, 08:52 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
have the alt tested.....if batt light is on alt most likely is dead
mjr46 is offline
Old 08-05-2014, 08:27 PM
bebermexico
no already checked before i posted this my electric fan is killing my alternator
Old 08-06-2014, 08:48 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Is this a statement or a question?
Without proper punctuation, it's hard to understand.
An electric fan puts a pretty big load on your charging system when they first start up, but even a stock alt. should be able to handle it. Once the fans on, it draws a lot less power. But your saying your Alt. Light is on whenever the fan is on? And your battery and Alt. tested good?
88 orangepeel notch is offline
Old 08-17-2014, 06:50 AM
robotnix
robotnix's Avatar
go with a 3G (130) if you change alt. a bit more work but worth it.
I do have an electric fan as well and have no issues at all.
robotnix is offline
ak98
02-18-2023 08:36 AM
aznpersuasion
07-11-2018 06:40 PM
11-10-2015 11:39 AM
TfcCDR
09-14-2015 12:08 PM
09-03-2015 07:14 PM
Quick Reply: electric fan problem'o
