PCV Valve - HELP!!!
Old 07-27-2014, 11:11 AM
WHTEVNM
WHTEVNM's Avatar
Default PCV Valve - HELP!!!
I was driving my car yesterday and all of a sudden it began smoking a little bit from the engine bay. When I stopped the car and popped the hood I could see oil splattered on the back of the engine bay and oil leaking out the bottom of the back of the engine. I let it cool down and while I was snooping around I found that the pcv valve on the back of the lower intake had come out of it’s place. I cleaned everything up and put the valve back in. After researching this topic I found out that there is supposed to be a little filter that sits in the grommet for the pcv valve? Mine didn’t have one. I’m kind of worried that it fell inside the intake? Is that possible? Also, is it a common problem for the pcv valves to pop out on these cars? The motor has been rebuilt so I am hoping that they just left it out and it didn’t fall inside the intake. Thanks for the help.
(95 Cobra, no blower or turbo, the car has some bolt ons but nothing radical)
WHTEVNM is offline
Old 07-27-2014, 03:29 PM
bluebeastsrt
bluebeastsrt's Avatar
The grommet/filter most likely popped out and you'll need a new one. Its likely to big to go inside the intake. Check to see your valve covers are vented properly. If not that's most likely what caused it to pop out in the first place. Also give the valve a good shake and listen for a rattling noise. If you don't hear anything replace the PCV valve also.
bluebeastsrt is offline
Old 07-27-2014, 06:13 PM
JPJP
JPJP's Avatar
Double check that it isn't in the intake manifold. It does not belong in the grommet but rather between the grommet and intake manifold.
Sometimes it is hard to see. It took me a dental pick to catch it and pull it up.
JPJP is offline
Old 07-28-2014, 10:31 AM
WHTEVNM
WHTEVNM's Avatar
Thanks for the information guys.
WHTEVNM is offline
Old 07-28-2014, 10:35 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
it can't fall into the intake guys!! there is a blocked portion to prevent this on the intake......................
mjr46 is offline
Old 07-31-2014, 06:21 PM
JPJP
JPJP's Avatar
Agreed!
JPJP is offline
Old 08-05-2014, 01:40 PM
yurizx6r
yurizx6r's Avatar
You need to make sure that aluminum filter/mesh is in there! It will not fall inside the intake and blow your motor up or anything. It's just like how a sewer cap is... it's round so no matter what angle you try to drop it, it will not fall inside the hole.
http://www.latemodelrestoration.com/...-Filter-Screen
Remember, it goes aluminum filter/mesh, PCV valve grommet, and then the PCV valve. The guys who did the motor just probably forgot to put it in.
yurizx6r is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
svfetter
10-05-2015 11:39 AM
lmurf60
09-24-2015 10:07 PM
Ipaman
09-22-2015 07:01 AM
Quick Reply: PCV Valve - HELP!!!
