no smog and ac
Old 10-16-2005, 07:06 PM
drunkmustang
drunkmustang's Avatar
Default no smog and ac
does anyone here run withot their ac and smog pump, ive seen the ford racing kit for removing the ac and the idleing pulley for taking out the smog pump, how do yall hav it set up and what size belt do you now use
drunkmustang is offline
Old 10-19-2005, 11:17 PM
OneFine89Mustang
OneFine89Mustang's Avatar
Default RE: no smog and ac
i eliminated my ac i bought off summit the trick flow ac bracket. you move the belt tensioner over to where the ac used to be and the bracket bolts to the water pump and the power steering. and the tensioner is held in by the bracket. im not sure about the belt size but i know the last digits is a 70
OneFine89Mustang is offline
Old 10-20-2005, 01:38 AM
ricepatrol
ricepatrol's Avatar
I'm also interested in this info- I want to remove all the smog+ac stuff.... what exactly is needed.... a special bracket like mentioned above for the a/c, but the smog can just be bypassed? I remember reading about plugging some stuff up that was related to the smog... And I imagine the trick flow bracket was probably way more expensive than a summit brand... anyone else deleted both? Thanks guys
P.S.- I'm parking the stang for the winter, but i wanna buy the stuff over winter...
I plan on deleting the a/c, smog, add pullies, and advance timing before spring
Estimated HP gains? I'm thinking in the neighborhood of 20hp...
I would do more, but I'm also replacing the top, some ponys, getting a new front bumper (with the grill insert... I love em), getting a spoiler, and a spanking new paint job...
oh yea, plus investigating clutch issues...which is a whole monster in itself (I step on the clutch, and a hear a high pitch noise, it reminds me of what would be generated if you spun something really fast, and kept poking it with metal, like when you grind some metal down, except it pulses; plus I have vibration on slow takeoffs, along with clutch slippage)
sorta added a whole new post on top of this one... my bad [:@]
ricepatrol is offline
Old 10-20-2005, 01:52 AM
primetime5.0
primetime5.0's Avatar
ive deleted the ac and smog, it was very easy, i suggest buying the FMS eliminator its way better than any other ones that move the tensior over. as for the smog just remove it and run the belt like you normally would just no smog.
primetime5.0 is offline
Roxon68
03-17-2016 08:13 PM
Teddi
09-29-2015 12:24 PM
rafotree
09-22-2015 03:55 PM
wawagner82
09-13-2015 09:02 AM
J.casone400
08-28-2015 09:33 PM
Quick Reply: no smog and ac
