Running hot....!!!!!
Old 10-01-2014, 08:41 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Make sure you have all the air out of the cooling system and verify if thermostat is opening. If not, replace thermostat, or test it first. If that checks good, then start looking at the water pump.
88 orangepeel notch is offline
Old 10-01-2014, 09:39 AM
87droptop
87droptop's Avatar
How do i get the air out of the cooling system??
87droptop is offline
Old 10-01-2014, 11:22 AM
88 orangepeel notch
On a cold motor, I fill the radiator not quite full, start the motor, let it warm up. When the coolant in the block gets up to 180', 190' the thermostat should open and allow the coolant to circulate. The level in the radiator will drop, so have some extra ready to slowly add. You'll see bubbles and air pockets coming out the rad. neck. When level seems to hold at about 2" below neck, throw the cap on and drive the car for 10 min. Keeping an eye on the temp gauge, just in case.
Park the car and check level at the reservoir, add THERE if needed. don't remove the rad. cap. Just saying as I don't know your "skills" (as a reference to a great movie.)
10-07-2015 07:02 PM
heslekrants
09-23-2015 04:02 PM
TorinoCobra070
SVT Forums
09-18-2015 10:34 AM
MusicCity615
09-12-2015 07:05 AM
uedlose
09-10-2015 03:30 PM
Quick Reply: Running hot....!!!!!
