Running hot....!!!!!
Old 09-17-2014, 08:45 AM
87droptop
87droptop's Avatar
Default Running hot....!!!!!
Hello I need help ASAP...
My 87 drop top is all of a sudden running hot on idle. when i crank it the temp rises to the N and then the smoke start coming through the defrost vent. Im kinda thinking it may be the thermostat...... thats the only thing i have not changed out. 3 row radiator new hoses. PLZZZ HELP....
87droptop is offline
Old 09-17-2014, 09:04 AM
coops coupe
coops coupe's Avatar
Smoke through the defrost vent, do you smell coolant ? I would first check the heater core.
coops coupe is offline
Old 09-17-2014, 09:14 AM
87droptop
87droptop's Avatar
yes i can smell the coolant..... think it might be a bad heater core??
Old 09-17-2014, 09:22 AM
dawson1112
dawson1112's Avatar
ITs the heater core. only way for steam to come through the defrost.
dawson1112 is offline
Old 09-17-2014, 09:25 AM
87droptop
87droptop's Avatar
thanks guys. gonna be a few hour project but cheap fix.... thanks
Old 09-17-2014, 09:27 AM
87droptop
87droptop's Avatar
Will that solve my heater problem also?? cause it doesnt work
Old 09-17-2014, 10:08 AM
dawson1112
dawson1112's Avatar
It should
Obviously its been leaking for quite some time, and running low on coolant. Usually the first thing that happens is it quits blowing hot air because there is no coolant in the heater core any more. Im actually pretty surprised that you didn't notice the floor on the passanger side being wet at some point when it first started to leak.
Old 09-17-2014, 10:51 AM
coops coupe
Originally Posted by dawson1112
It should
yep and the funky antifreeze residue on the windshield ......
Old 09-17-2014, 12:14 PM
87droptop
87droptop's Avatar
It should
yes the floor has been getting damp since i got the car back in november but just started doing this recently. i guess cause the mississippi heat getting to it. Im restoring the car. i drive it like 2 a month so this was expected.
Old 10-01-2014, 08:28 AM
87droptop
87droptop's Avatar
Default Heater core replaced...
I have replaced ther heater core but yet it still chooses to run hot. i actually think it is the thermostat because the hoses off the heater core are hot but the radiator is cool. so i guess the thermostat is not relieving the hot fluid back into the radiator..... COMMENT plz.... need the car running right soon. plan to take it to crusing the coast in gulfport next weekend.
Quick Reply: Running hot....!!!!!
