Hi im doing a swap in my 1989 foxbody and im going from a 1989 HO 302 to a 1994 302. im using the power steering pump, alternator, tensioner, and crank pulley off the 1989 but for some reason the water pump pulley i have doesnt line up with the other pulleys and i cant seem to find the right pulley anywhere. thoughts?
The 94 water pump is different from the 89. It is shorter than the older one. You will have to swap the old pump and timing cover over to get it to line up.
They will both fit each block but the water pump side is different. The 89 requires a backing plate on the pump and has more square coolant ports. the 94 doesnt require the plate and has round ports.
