Most of the big things
I am about to purchase a 95 GT 5 speed. The motor has GT40 heads/upper/lower intake, B303 cam. 70mm throttle body, longtubes to flowmasters, EGR delete, Trickflow cai, and underdrive pullies. But due to the guy selling a few things to his friend. The car has a stock maf, ecu, and stock injectors. What maf, ecu, and injectors should I go with? Also, what kind of whp increase will I see from adding these mods? What would you say its putting down now? Will the car be too lean without #24's? I used the search and couldn't find much on the topic.
No gains at all. Your not going to gain any more from larger injectors, because the engine can not use the extra fuel with out better heads and a better intake. The maf is only there to tell the computer how much fuel is needed, and the heads and intake limit you on how much air can be drawn in. Your money would be better spent on changing rear gears to a 3.73 or 4.10 set.
The egr code can be turned off with a tune, but its a little pricey to just turn off the egr. If your not getting any lean/rich codes then your ecu is doing its job. And other than adjusting your timing advance a tune isn't going to net you any more power. You can adjust your timing advance manually at the distributor and get the same effect a tune would get you.
Again I say spend your money on gears, it will make a significant difference , and one that you will feel instantly once completed.
http://www.westsidemustangs.com/show...MIL-Eliminator
Luke9222
10-22-2015 11:55 PM
mungodrums
09-28-2015 10:54 PM
