94 Mustang Clutch
Old 10-20-2014, 05:38 PM
HillbillyLambo
HillbillyLambo's Avatar
Default 94 Mustang Clutch
I am new to this forum as well as working on cars. I am looking into my first big job by myself and that is going to be replacing my clutch on a 1994 Mustang GT. Currently I am trying to order the parts and I have become confused. Is the clutch I need to buy just any T5 clutch? Thank you!
HillbillyLambo is offline
Old 10-20-2014, 08:56 PM
dawson1112
dawson1112's Avatar
http://www.americanmuscle.com/ford-r...sAAw&gclsrc=ds
dawson1112 is offline
Old 10-20-2014, 09:30 PM
HillbillyLambo
Thank You!
Old 10-20-2014, 09:49 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
do you want an oem replacement or a upgrade performance one?
mjr46 is offline
Old 10-21-2014, 04:55 AM
barnett468
barnett468's Avatar
hello;
are you planning on replacing the pressure plate also. they are often worn beyond the service limit and need replacing but its impossible to tell until you take it out and look at it.
it's also common practice to resurface the flywheel. if it has some dark spots on it, hairline cracks and/or the surface is not perfectly smooth i suggest you get it resurfaced for sure.
also possibly a new bearing, especially if yours is really old.
barnett468 is offline
Old 10-26-2014, 03:07 PM
HillbillyLambo
I am going to just get a new flywheel and new bearing barnett468. mjr46 I am probably just going to buy the one in the link from american muscle.
Old 10-26-2014, 07:31 PM
Js88lx
Js88lx's Avatar
ive had the king cobra clutch and was a tad bit too stiff. I use this one and I think its way better than the cobra clutch and cost just barely anything more!
http://www.americanmuscle.com/ram-hd...45-clutch.html
Js88lx is offline
Old 10-31-2014, 09:01 PM
HillbillyLambo
I bought the RAM clutch, but i was curious what is the bearing I should buy along with the flywheel? The main problem with my clutch right now is that when I take off in first gear there is whistling sound which I assume is the clutch. The newest problem with the clutch is when I start to slow down in neutral it will start vibrating for some reason only decelerating.
Hopefully i get the parts needed to fix these problems
Old 11-08-2014, 02:31 PM
Js88lx
Js88lx's Avatar
Its called a throw-out bearing. Also change the pilot bearing behind the block!!
Vibration could be anything. Just replace the clutch/bearings and new or re-surfaced flywheel and you should be good to go! Good luck!
Js88lx is offline
djbigskrilla
09-20-2022 01:04 AM
Urambo Tauro
12-17-2016 03:30 PM
Jskeezy84
09-08-2015 01:40 AM
ponyride00
08-12-2015 01:57 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 94 Mustang Clutch
