no start, fuel pump not priming
Old 11-21-2014, 02:45 PM
9165pt0
9165pt0's Avatar
Default no start, fuel pump not priming
Hey guys car didnt start the other day, finally started and ran for 2 days n now doesnt run. The fp isnt priming, whats odd is even the audible dinging sound for key on dopr open is very faint. I have teated and swapped fp relay, all wores are getting power, the pink blk wire isbgetting a constant 5v for aome reason. Thr inertia switch has 12v each side, swapped eec realy and a known good ecu, fuel inj show full,voltage, even during koeo the fp will not prime, i get a code 95, i jumped the fuel pump test port to ground and all i hear is a click still no prime. I do not undrrstand how the pink black wire has 5v to it when not priming? Grounds all look fine, im stumped.
9165pt0 is offline
Old 11-21-2014, 04:46 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Ford Generic Code 95:
(O)
Fuel pump: open, bad ground or always on – Power / Fuel Pump Circuits
(R)
AIR not Diverting (AIRD) – Air Injection
(M)
Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) – Power / Fuel Pump Circuits
(R) = Engine Running test (M) = Memory code (O)=Key On Engine Off test
http://www.troublecodes.net/ford/
and specific to Mustang specifically:
95 - Fuel Pump Circuit Open-PCM To Motor Ground (CM,O)
O—Key On, Engine Off code.
CM—Continuous Memory code.
R—Engine Running code.
http://dfwmustangs.net/forums/showthread.php?t=7908
Someone else with more experience on your year of car will chime in but how's the harness look?
The "Always Powered/On" caught my attention both on your explanation and the Code trouble shooting chart above.
Derf00 is offline
Old 11-21-2014, 05:21 PM
9165pt0
9165pt0's Avatar
Yea the pink blk wire always has power but not full voltage. Thats whats confusing me. Bcuz pump doesnt prime. Bad ground makes sense, idk if the faint door open ding sound is related to the same bad griund as the fuel pump?
Ill have to keep looking through the wiring to find it.
9165pt0 is offline
Old 11-21-2014, 09:39 PM
ticopowell
ticopowell's Avatar
Check your battery... All I can think of :/
ticopowell is offline
MEISTERSNFB
03-31-2020 07:50 AM
Design1795
01-24-2017 10:38 PM
SYNY5TER
09-02-2015 01:35 AM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: no start, fuel pump not priming
