Engine Block Information?
I'm trying to find out more information about an engine I bought?
I'm not having much luck.... Block code: F1SEBB
Thanks, KJ!
txoldrodder@att.net
Thanks, KJ!
txoldrodder@att.net
Should also note that just because it is stamped 91 thunderbird , does not necessarily mean it was used in a thunderbird. Ford used that block in several cars, and if there were F1SE blocks left on the line when they switched over to a different model or model year they used the remaining F1SE blocks first.
It is a very common 302 roller block.
doesn't mean it's a 91......that's just the start of the new casting code.....e7 casting code went until then so in theroy it could of been for example if it carried a e7 code from 87-90 or 91 until all those casting codes were used up
