turn signal driving lights help!!!!
I have a 90 mustang 5.0. Alright I have a decent amount of problems with lights all fuses are good didnt check relays. I dont have dash lights turn signals and parking lights. For my hazards I have all left side and one bulb in the back right corner. Interior lights work headlights work habeas work reverse lights work and brake lights work. I use to have rear parking lights now I dont. All bulbs are good fuses are good. Any help at all would be much appreciated. Thanks!
Jeez, talk about a can of worms lol. Welcome to the forum by the way. I don't even know where to start.
Dashlights..... Verify you don't have a dead spot in the dimmer switch/dial. My car does but it's not worth fixing as it's near the lowest setting.
As for the rest of the electrical gremlins, all you can really do is back trace the wiring to see what's stopping it. Verify bulbs and sockets are clean and greased. No corrosion is allowed. Good luck
Someone may jump in here and give better advice, but that's where I'd start.
Thanks . I use to have left turn signals and dash turn signals now I have nothing for turn signals. Do you know where the relays are located? This car has definitely been molested in the past missing a lot lol
simple test light at the socket and a wiring diagram will work wonders at letting you know which side of the circuit to trace....................start at on end/bulb socket that doesn't work and check the power and ground to it....which ever is missing, work in reverse and trace that side back to point of orgin to see where the power or ground gets lost.
Still no turn signals. I have four ways in the front but passenger aide is dimmer then the driver side. I think the socket is a little messed up. I have the rear disconnected. Rear grounds are all jazzed up. This car is absorbing mess. A lot under the dash is unplugged. Cant find wiring harness pic anywhere
Ok so I have four ways still no marker lights turn signals or dash lights. Reverse light head lights high beams and hazards. Im thinking turn signal switch if you guys can thing of anything else that'd be much appreciated. Also my side markers are pretty dim. Every bulb is brand new. Thanks
I told you what you NEED to do.............dim = bad connection or ground issue or something causing high resistance in the circuit.
