stang has no power won't start
i replaced the dizzy module afew weeks back. car died before and turned out if i let it sit and cool down it would start and even keep a idle for afew mins then it would die i changed the module on the dizzy and it fixed that issue.
now afew weeks later car has no power new battery/pos/neg cables and also solidnoid was changed and no go. dead no power at all no keys in car and when door open the check engine/oil/air bag lights come on same when power windows/door locks tryed.
any ideas
any ideas
RE: stang has no power won't start
Brand new battery and Brand new pos/neg cables nice and tight and it has lots of juice. theres not even a click when trying to start it's just DEAD. when door open or power windows or door locks even tryed with no keys in car the lights in dash show check engine/oil/air bag. Won't take a boost nothing. Ground and power both good battery good. Solidnold new and Dizzy module changed also.
ORIGINAL: Madskillz306
any ideas
any ideas
If you short between the hot side of the solenoid and the small post on the solenoid, does the engine turn over? If it does, your problem is in the ignition switch, fuses, or wiring. The wire is connected to the small post of the solenoid, right? Based on what you've said, I strongly suspect that you have a bad ignition switch. Note that the ignition switich is down on the steering column, it's not where the key goes into the lock/tumbler.
