85 5.0 carburetion
Old 03-07-2015, 11:28 PM
barnett468
barnett468's Avatar
Originally Posted by tramphardrocker
After reading up more on these issues, I learned that what u are saying is true. If I do anything, it will be to replace the Holley (California) with an Edelbrock set up for my elevation. Still working my way up the learning curve. Thanks for the advice.
This intake will give you some of the best overall power at your elevation on that engine.
square bore intake
http://www.summitracing.com/parts/ofy-6009dp
spread bore intake
http://www.summitracing.com/parts/ofy-6010dp
egr adapter page 16.
http://www.offenhausersales.com/Offenhausercatalog.pdf
barnett468 is offline
Old 03-12-2015, 11:26 AM
tramphardrocker
tramphardrocker's Avatar
I'm in a county that doesn't require smog tests yet. When I got this car the smog pump was siezed, the belt was rerouted without an eliminator kit, and all the vacuum lines involved in EGR were cracked and rotten. I want to eliminate all of that stuff but I understand that there are issues regarding plugging holes in the heads and the cat on the exhaust. What do I have to do to safely eliminate all aspects of the smog system? If I eliminate the cat can I just plug every vacuum port associated with the smog system?
tramphardrocker is offline
Old 03-12-2015, 01:53 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
take it off and cap all vaccum lines....that's it
mjr46 is offline
Old 03-23-2015, 12:48 AM
tinman
tinman's Avatar
If you live at a 5200' elevation the carb may very well have the wrong jets in it. You may need 1-2 sizes SMALLER. Even at this time of year your true air density could easily be 7000'. The 85 carb is really about like a 600 Holley with a vacuum secondary
I'd sure keep it before I went CFI or got any Edelbrock carb.......
I'm also thinking that the original carb is one that uses a metering plate on the secondary side so I would convert it to a metering block (easy to do).
tinman is offline
Old 03-23-2015, 09:49 PM
tramphardrocker
First off, thanks all for the advice. The only thing I'm doing is going to BBk headers and dual exhaust. No smog where I'm at. Leaving the carb alone. Why fix it if it ain't broke. Doing this on the cheap. Can't make a silk purse out of a sow's ear without ponying up a lot of bux. Junkyards and C'list are my main suppliers . Just hope it goes kinda fast.
Old 03-24-2015, 11:53 PM
tinman
tinman's Avatar
Originally Posted by barnett468
the compression on these was a little low from the factory but yours is extremely low due to your elevation, milling the heads to increase compression will get you noticeable improvements but if you mill them too much then it will ping/detonate a bit at sea level.
Barnett 468: could you explain how this works?
tinman is offline
Old 03-25-2015, 08:50 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
i wouldnt waste any time on the stock heads the e5 arent anything special. for a budget up grade find a 1996-97.5 explorer with the 5.0. take those heads and have them milled. they are gt40 heads. with a new cam and some roller lifters youll basically have a poormans 93-95 cobra motor on your hands
rmodel65 is offline
Granatelli Sales
03-25-2016 08:01 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 85 5.0 carburetion
