Roller rocker adjustment question
Hey guys, this is my first time adjusting roller rockers. My question is if a cylinder is on overlap, is it normal to be able to move the push rod up and down!?
I did exactly what trick flow said (Trick Flow heads and push rods) put cylinder #1 on TDC then tightened the rocker until I could not move the push rod back and forth. Then I tightened the push rod almost half a turn, then took my hex key in sequence with my wrench to complete the half turn. Moved the crank 1/4 turn, and then moved to the next cylinder in proper sequence (5, etc, etc,).
I also just realized that maybe I did it in the wrong order? Mine is a 93, so with a Ford E303 cam, do I use 1-5-4-2-6-3-7-8 or the 1-3-7-2-6-5-4-8 firing order?
Scratch that. I just realized that I did do the wrong firing order. lol It's a 93, so it's an H.O., so that firing order is 1-3-7-2-6-5-4-8. I just verified this by my distributor cap.
I just redid it and now everything is pretty snug/tight all the way around. Except for one piston, you can move a push rod a little, but not that much. I knew something was up.
scroll down to preferred valve adjustment = only real way to do it for stud mount and get it right the first time!
http://www.flowtechinduction.com/tech-info/
They are stud mount.
I'm going to recheck them tonight when I get home before I put the valve covers on. When a cylinder is on overlap, how tight should the push rods be? should you be able to twist them at all?
I'm thinking that way makes more sense. Thank you for that. I guess I will do that tonight and and stick with half a turn. I just don't feel like throwing away 40 bucks in gaskets if I have to take off the manifold and valve covers again.
you shouldn't have to throw away any gaskets, the upper plenuim gasket, if I'm careful enough I always reuse and as long as you aren't using cheap cork gaskets for the rocker covers, you'll be fine....I always use the reusable rubber valve cover gaskets
I never go cheap on gaskets either, but I'm saying once they have been through a few heat cycles I always change them no matter what. I have not put the valve covers on yet, so I'm fine there. I ran into another problem last night, a plug in one of the bolt holes where the main stud for the power steering shaft and a/c line go into. That's what I get for buying used heads. Couldn't get it out, so I'm calling in a buddy.
