fox running 200 degrees
Old 06-11-2015, 09:31 PM
mikesr4565
mikesr4565's Avatar
Default fox running 200 degrees
the summer is heatng up and my fox is running at 200 degrees. she normally runs at 190. i want to know if it is safe and also want to take a 500 mile trip soon. i have 3.73 gears and dont know if the heat,temp,gears will hurt her on a long trip
mikesr4565 is offline
Old 06-11-2015, 10:41 PM
jwog666
jwog666's Avatar
200 isnt that hot, but if u want it cooler, i suggest changing the t-stat out for a 160 deg. and perhaps switching over to an electric fan if not already equipped, if the radiator is stock i have run into some with plugged tubes
jwog666 is offline
Old 06-11-2015, 10:56 PM
MtnMustang
MtnMustang's Avatar
I agree, 200 is ok, if you are constantly over 210 then I would be concerned.
MtnMustang is offline
Old 06-12-2015, 06:42 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
not on a fox....coolest stat you need to go on a fox is 180 to properly maintain closed loop operation............as stated 200 isn't hot, and if all cooling system components are operational and your radiator isn't partially restricted due to calcium build up, then I'd do a 180 stat and a hd aluminum radiator with larger cores
mjr46 is offline
Old 06-12-2015, 08:37 PM
mikesr4565
mikesr4565's Avatar
thank you. am running a electric fan but also just a stock radiator
Old 06-13-2015, 11:50 PM
65Raven65
65Raven65's Avatar
I agree with mrj46.
It may depend on how hot your area gets, but I know around here (Houston, TX) the general consensus is 180 works best for around here.
160 is too cool, it never ends up closing during the summer, and causes other issues.
Your mileage may vary of course, good luck!
65Raven65 is offline
Old 06-18-2015, 08:25 PM
SWGSSSlacker
SWGSSSlacker's Avatar
Your serpentine belt is routed correctly?
SWGSSSlacker is offline
mtgldr
02-03-2024 09:00 PM
carid
07-08-2016 09:55 AM
uedlose
09-10-2015 03:30 PM
96stang3.8
09-10-2015 06:42 AM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: fox running 200 degrees
