1992 Summer Edition - Wont start!
Im brand new here... & I hope im posting this in the correct forum. Just bought a 92 red & white garage kept mustang 5.0 conv.
I think its the eec and am considering sending it out for rebuild - since I cann not find any matches in a scrap yard.
Here what drew me to this conclusion... Please chime in if you can help..
*no spark - no fuel - no run*
-Check engine light does not come on when ignition switch is placed to on.
-power good to eec coming out of relay
-12 volts @ icm, but no ground - this ground seems to come from eec
-12 volts @ fuel pump relay - again the ground signal should come from the eec. not present. The pump does not run for a few secs when key is turned. the pump runs when relay is jumped.
-the grounds are good coming into the eec via harness and ground connection in vicinity of eec is good.
Thanks,
Rob
Thanks,
Rob
M3hunter
09-05-2015 03:42 PM
