1990 5.0 dead - MustangForums.com
1990 5.0 dead
Old 09-08-2015, 05:15 AM
1TUFF302
Default 1990 5.0 dead
Took my car out last week drove about half hour and it died,no spark no gas smell can hear fuel pump prime,replaced the dist and TFI did no good.left car in lot came back with trailer and car started.got it back home and let it sit for 4 days,it stared up let it get hot was working fine,tested with scanner had some codes about no power to ecm.I ran a couple test with KOEO and then i got it now my code on scanner is 15 prom failure and yep will not start.Took out my chip and still will not start but I did get it to run a couple of times but ****y and died.Any body know were i can get my A9L repaired at.
1TUFF302 is offline
Old 09-08-2015, 08:19 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Sorry, I don't know of anyone around us that repairs them. When mine went bad, Autozone carried remanufactured ones for $100. That was 5-6 years ago though. Good luck
If you find any information in this fix, be sure to post back with an update as I've been seeing more and more ECMs failing lately and no real fix except taking your chance on eBay ones. Normally these computer's have had a very good reputation.
88 orangepeel notch is offline
Old 09-09-2015, 04:30 AM
1TUFF302
ecm are on ebay but I think I am going to have it repaired.
1TUFF302 is offline
Old 09-09-2015, 08:04 AM
88 orangepeel notch
OK, post back if you find a place that repairs them and the cost/warranty info.
Just to help the next guy out who may have similar problems. Good luck
Old 09-11-2015, 03:40 PM
silver91gt
check the fusible links for the ecm power before you replace anything.
silver91gt is offline
Old 09-11-2015, 04:28 PM
1TUFF302
when it sat for 4 days and started I dont think its the links plus when it happen the first time it started and sat I drove it up the trailer and checked all grounds.
1TUFF302 is offline
Old 09-30-2015, 05:56 AM
1TUFF302
well found a a9l computer for 100 bucks and it does start and run just have not taken it out for a drive yet.just over 300 bucks you can have them repaired,this was cheaper for me.
1TUFF302 is offline
Old 09-30-2015, 08:50 AM
88 orangepeel notch
Good to hear, thanks for the update. Was this a used ECM or remanufactured ?
Old 10-31-2015, 03:23 PM
Tribefan
Tribefan's Avatar
wrong thread. sorry
Tribefan is offline
Old 11-05-2015, 04:20 AM
1TUFF302
yes used,took out my old distributor and found the gear all most gone,trying to find out what gear to use for the x303 cam from ford.
i dont take it out much
1TUFF302 is offline
Quick Reply: 1990 5.0 dead
Featured Sponsors
