oil dipstick tube broke off block
95 gt
my oil dipstick tube came out of the hole in the block or pan, whichever it goes into.
i had been just putting it back in the hole and going about my day, but now that im fixing thingsm figure i should fix this as well.
so, how do i fix this?
thanks in advance
thanks in advance
Not real sure what your saying. If the tube came out put it back in so oil doesn't go everywhere. If it's broke off and part of the tube is still there het an easy out and tap it into the tube and extract it.
the entire tube comes out of the hole. i normally just put it back in, but its not a tight fit by any means. is it supposed to be like that? perhaps because the bracket at the top of the tube is broke it allows this to happen? (the support bracket at top that is supposed to bolt to the block(or the head, cant recall))
Tube might be wore out or out of round. Try putting a little gasket sealer on it before you put it in. The bracket that holds it in place would keep it from moving and falling out again. Sounds like it's time for a new dipstick assembly to me.
they had a straight tube, but thats not whats on my car.
will post a pic of the end when i get a chance
95V8
11-10-2015 12:36 PM
10-23-2015 11:58 AM
