Differences Among Harmonic Dampers/Balancers
I'm preparing to replace my harmonic damper/balancer, but I see there are different kinds available. Most regular units are in the mid double-digit price range, but I see some "racing" ones that are significantly more expensive.
What is different about them? Are the cheaper ones less capable of doing their job? Is it a longevity issue? What is it that you're paying for in a high-end unit?
Mostly in materials. Stock ones are rubber bonded to metal. Race ones have more durable urethane or all metal construction. Some of the more expensive ones have removable weights. What are your goals with the car? Stock will dampen vibration better but not stand up as well to constant high revs.
Hm. Sounds like a real one-or-the-other trade-off. For a daily driver, I would certainly choose vibration dampening over high-rev longevity. There doesn't seem to be anything to gain from putting a race unit in a street car. I will pursue an OEM-type replacement.
When we're talking about "high revs", are we talking about the stock redline area of ~5900ish RPM? Or are we referring to race engines that are built to exceed that?
In response to your last question mostly the high rev race prep motors. It's not just the revs but the high heat those motors experience. Most foxes have been beat on at least a little and the stock balancers survived for 20 years. A stock style replacement will be fine for stock to mildly built engines.
mikelieb1289
01-05-2016 11:56 AM
