nos
nos
for the past couple days ive been thinking about getting nos but im not too shure what brand and how big of a shot. im only going to use it on the track and only once in a while on the street, so i dont need nothing to big. my cars carburated and i seen the power shot by NOS, is that any good ? its a 125 shot, is that alot or should i go with the super power shot which is 50-150hp ?
RE: nos
yeah thats y i was thinking about a 75 shot. i think i might go with the super power shot and put the 100 shot in. any body else that has no2 have any suggestions on which kind to get?
RE: nos
You will be fine with a 100 shot. Pull about 4 degrees of timing. If you have a 5 speed use a window switch or a wot switch. If you have a good ignition sys you can leave the plugs that you are running in. Close the gap about .005. Last but not least make sure you have enough fuel going to that motor.
RE: nos
do it...100 shot is fine but your more comfortable w/ 75 jets for now do that.
i like NOS dry kits and zex dry kits, haven't used any others...the zex is a super fast and easy install.....
RE: nos
I have hyper pistons, and I am only going to spara a 75 shot, but not yet.
I have to let my motor break in.
on my old stock motor I sprayed a 125 shot and my ET was 4 tenths slower than with the 100 shot.
100 shot ET 13.2
125 shot ET 13.6
both mph were 107.
125 shot spun bad in all shifts.
boy does it put a huge smile on your face though.
I think I am going to get a blower though, because I want that power all the time.
wet kits are good for carb.
100 shot ET 13.2
125 shot ET 13.6
both mph were 107.
RE: nos
ok i think i have narrowed it down to two the NOS super powershot kithttp://www.jegs.com/webapp/wcs/store...0321&langId=-1 or the NX hitman nitrous system http://store.summitracing.com/ which one should i go with ? my friend said that nitrous express is better. whats a window switch and where can i get one? and a wot switch? which one is better? i have a red holly fuel pump, not shure how much it pumps
