lb injecters in my 94 mass air and 24 inj
if I install 24lb injecters in my 94 will I need a bigger mass air right away or will my car run fine till I can afford one? I'm getting a tf top end kit installed and the place is going to recalibrate my computer. Will my car be fine without the bigger mess air till I can afford one?
RE: lb injecters in my 94 mass air and 24 inj
Just make sure you get your mass air calibrated for the 24's. I think it will run fine, you will be losing some power. I have a c&l I will sell for a 100 bucks shipped. It is a 76mm calibrated for 24s but it is for a 89-93, im pretty sure it will work on a 94. You should be able to bolt on your mass air harness and it should work fine. They calibrate the c&l through the tubes.
jwog666
12-27-2021 08:09 PM
