ROUGH IDLE CAM
ROUGH IDLE CAM
OK I FIRST POSTED THIS IN THE NEWBIE SECTION, THAT MIGHT HAVE BEEN THE PROBLEM. BASICALLY I WANT A VERK NOTICEABLE ROUGH IDLEING CAM. YOU KNOW THE ONE THAT SOUNDS LIKE THE CAR IS BARELY RUNNING.WHO MAKE ONE LIKE THAT BUT ALSO HAS TO BE COMPUTER CAPEABLE.BUT REMEMBER VERY VERY ROUGH IDLE. WHOS GOT IT AND HOW DOSE IT PERFORM.
RE: ROUGH IDLE CAM
you want a very rough cam, ford racing makes just what you want. its called cam-zilla. fords Z303 cam its the biggest baddest cam ford makes, i used to have it, but i went with the E303 cam instead, it has similar results, it idles like the old muscle cars, it nice but probably not what you want. try it out or call jegs and ask for it.
RE: ROUGH IDLE CAM
Not to nag or anything, but if your car's otherwise completely stock, a high-lift, long duration cam will probably make your car slower. Those cams really make their big gains higher up in the power-band. Also, those cams might not be compatible with an auto trans if you have one.
RE: ROUGH IDLE CAM
NO THE CARS NOT STOCK OR AUTOMATIC. I HAVE BBK LONG TUBES WITH NOT CAT H PIPE SLP LOUD MOUTH 75MM THROTTLE BODY WITH EGR AND R SERIES MANIFOLD.PLUS THE CAM I SELECT IS GOING ON WITH MY AFR 185 HEADS SO WHICH CAM IS IT DOES ANYONE HAVE ANY SOUND CLIPS OF ONE IDLEING.
RE: ROUGH IDLE CAM
If you're looking for something specific, i suggest you call a major cam maker, (comp cams, etc) And if you tell them your mods and what you're looking for in a cam, they can either reccommend one for you, or probably custom grind one
