Fuli psi for 89 5.0
Old 04-13-2016, 08:27 PM
Jakobj
Jakobj's Avatar
Default Fuli psi for 89 5.0
Is the psi pressure on my fuel rail supposed to drop? When i turn the key on it hits 42 psi. When i shut the key off the pressure drops and bleeds off. Im new to fuel injection. Car wont start just cranks over.
Jakobj is offline
Old 04-14-2016, 04:04 AM
dawson1112
dawson1112's Avatar
No it should hold pressure. you have a leak in the system, likely the fuel pump check valve is bad.
dawson1112 is offline
Old 04-14-2016, 06:25 AM
88 orangepeel notch
88 orangepeel notch's Avatar
Welcome to the forum......
How fast does it bleed off ? My car holds pressure for 5 - 10 minutes, then very slowly drops a pound or 2 every half hour. Then the instant I turn the key, pump primes and pressure is right there again.
88 orangepeel notch is offline
Old 04-14-2016, 02:21 PM
Jakobj
Jakobj's Avatar
Default It bleeds off with in seconds after i turn the key off.
QUOTE=88 orangepeel notch;8539379]Welcome to the forum......
How fast does it bleed off ? My car holds pressure for 5 - 10 minutes, then very slowly drops a pound or 2 every half hour. Then the instant I turn the key, pump primes and pressure is right there again.[/QUOTE] It drops after i turn the key off. How much pressure should it be holding?
Jakobj is offline
Old 04-14-2016, 02:23 PM
Jakobj
Jakobj's Avatar
Thank you for the info. Can you tell me please how much pressure i should be getting whenthe key is on?
Jakobj is offline
Old 04-16-2016, 12:55 PM
alecracing
alecracing's Avatar
Stock should be 40-45 psi with engine not running, or engine running with vacuum line pulled of regulator...or 32-35 psi with engine running and vacuum line hooked up to regulator
alecracing is offline
Old 04-16-2016, 01:26 PM
Jakobj
Jakobj's Avatar
Thank you.
Jakobj is offline
04-13-2016 08:03 AM
04-12-2016 09:36 PM
heflinhunter
04-12-2016 11:59 AM
ThaiCobra
04-12-2016 09:33 AM
600014307
04-07-2016 08:27 PM
Quick Reply: Fuli psi for 89 5.0
