smoke
smoke
what would cause my car to all of a sudden push oil smoke out of my mufflers? the passenger side is really bad and the drivers side not as bad but still does. I have good oil pressure but my car has never smoked like it is now.t does it at an idle and really bad when I it the gas
First thing I would do is change the PCV. A failing crank ventilation component will cause it to have some blow by. If that doesn't solve the problem, then its time to move on to having a compression test done.
yes it is bluish smoke. I will try the options listed. also just to add I put 1.7 rockers on and didn't change my push rods. I was told that the push rods might have been a little to long and could have worn the valve guides, does that sound accurate?
nissen4
05-20-2016 07:46 AM
05-18-2016 01:27 PM
05-17-2016 01:15 PM
