found a coupe with a/c removed- help!
sold my hatchback, cause i want a coupe. found a coupe, but all the a/c has been removed, the only thing left is the vents and controls. how crazy/expensive would it be to have it all put back together. or is there another option if i want a/c. any imput would help. thanks john1614.,
RE: found a coupe with a/c removed- help!
If you install it you are looking at around 300-700. If you have a shop install you are looking around 1000-1500.
Its not that bad to install, you just need time. The dash will need to be removed if they pulled the lines out from the inside of the car too.
Plus you will want two people. It sucks to install with one.
Man it gets into the high 90's here so it made driving mine without AC a living HELL this past summer. Sitting at redlights are the worse because of all the heat the dang engine produces. I put my compressor back in and will hook the rest up this coming spring b/c 1 or 2 horses isn't worth it!
ORIGINAL: 92BULL1TT
Hey Dude hook a fan up with a power inverter duct tape it on to the mirror rig up a bag of ice with vents to go in behind it, AC DONE.... DOOO IT DOO IT......hahah I am from Canada I enjoy the whole 5 months of summer we get along with all the heat.
