Why wont my 347 crank up
I have fuel, it is reading 38 psi, and I have spark. I can't figure it out to save my life. [:@] It just turns over without cranking. There is no loaping or anything. It just spins over freely like as if it has no spark. Somebody please help.
RE: Why wont my 347 crank up
Is your firing order right? and is your dizzy right? and are you getting spark through the wire or just from the coil because i might be your rotor or your caps cracked? thats my guess o well good luck
My timing is set right and I checked my spark plugs by pulling them out with the wires still attached and I have fire shooting out the end of the plugs. I just don't get it. My ignition is all MSD and it's all brand spanking new stuff.
i had a simliar problem. believe it or not i didnt have any compression. motor spun easy and it did fire but not enough to kick over motor. i tried everything and found out that to be my problem
I guess from the pictures this is a new build? Most likely it is the timing, check it again to make sure you have timed it to Number 1 on the combustion stroke not the exhaust stroke.
